LabWindows/CVI
What could make HidePanel() not hide the panel? (2017)
We pop up a splash screen panel on startup:
if ((g_PanelSplashScreen = LoadPanel (0,  "PanelSS.uir", PANEL_SS)) < ZERO) return NEG_ONE;
SetCtrlVal (g_PanelSplashScreen, PANEL_SS_VERSION, _TARGET_PRODUCT_VERSION_);
SetCtrlVal (g_PanelSplashScreen, PANEL_SS_STATUS, "Loading user interface...");
DisplayPanel (g_PanelSplashScreen);
...and then at the end of the routine we hide it:
// Hide splash screen panel.
HidePanel (g_PanelSplashScreen);
But it often sticks on the screen and does not hide. Clicking on it makes it disappear.
If I run it in the Debugger (either Release or Debug build) it seems to work. But then if I run the .exe that was produced for the debug session, the panel does not go away. Weird.
Any thoughts on what could cause this?
(1,368 Views)
Try to use  SetPanelAttribute(panel,ATTR_VISIBLE,0) ;
(1,344 Views)
Ah, I had not thought of that.
I gave that a try this morning, and no change. BUT, it did lead me to what may be a solution.
We display the pop up, then eventually call a function that does startup things, and I SetCtrlVal() to a text field on the screen, giving status of what is going on. At the end of that last function, I would HidePanel(). Then, it goes back to main and displays something like "Starting user interface..." right before RunUserInterface(). I thought maybe modifying that panel was making it display. I commented that out, and still no change.
But, moving the HidePanel() there "seems" to work -- at least, I have tested it a few times this morning with no stuck splash screen. I am not sure why a HidePanel() only works "sometimes" in the function, but I'm going to test this more and see if this finally makes this panel hide properly.
(1,323 Views)
Have you ever tried trapping the return code from HidePanel ()? It could return a meaningful value that sheds some light on what's going on.
Just my 2c
(1,292 Views)
Just my 2c
Yes, early on, when this first started happening, I added error checking to that call, but it just blows on by.
Also, don't non success errors trigger a breakpoint, by default, when running in the debugger? I know SetCtrlValue/Attribute will break if the panel handle is wrong and the control ID is if the wrong data type.
(1,282 Views)
Roberto, you beat me to this idea.  I was thinking the same thing.  And this is generally a great, easy troubleshooting thing to do with all library functions!  Has rescued me more times than I can count.
(1,246 Views)
Check Run >> Break on >> Library Errors menu item: it is a bit obscure to me when the IDE breaks if this item is not checked.
(1,222 Views)
