LabWindows/CVI
What does ClearStripChart do?
Nothing happens when I call this function. Plots (lines of data) on the strip chart are still there after the call.
I want to clear the strip chart and start over as if nothing had ever been plotted. Is that possible?
(3,560 Views)
Hey Querty999 -
ClearStripChart should be exactly the function you're looking for.  In a quick test, it cleared my strip chart with multiple traces exactly as expected.  There are a couple of our examples that use this function - take a look at the <CVI>\samples\utility\Threading\ThreadSafeQueue\Overflow example for one place where it is used.  If you are still having some trouble, post the code snippet that doesn't seem to be working, and we'll take a look.
NickB
(3,557 Views)
