LabWindows/CVI
What is Multihread apartment? how to solve this issue
Hi All,
i receive the error below,  how to resolve this issue if i want it to run at the same time?
Library function error (return value==-180)
The dialog cannot be displayed in a thread whose concurrency model is multithread apartment(MTA)
Thanks 🙂
(6,864 Views)
The threading model has to do with how events are processed in multithread applications,  mainly when ActiveX objects are involved: here you can find an explanation if you want to deep into it. Apparently you are running into this error because you are calling some file dialogue in a multithread application that is using the wrong model: look at the notes given in the help, this is for example the page for .
(6,855 Views)
noted thanks for advice
(6,837 Views)
