LabWindows/CVI
What is the best efficient way to check if some elements in the panel (Or Ring) are not empty?
I am trying to put a test that runs after clicking start test on the panel:
I ve already written a code that starts the test after clicking on the "Start test" button:
Is there any function that I can use to check if the elements in the panel are all full and not empty? Thanks a lot in advance.
if(event == EVENT_LEFT_CLICK)
	switch(control)
case P_MAIN_Start_test:
 if ( P_MAIN_Operator != 0 && P_MAIN_ARTICLE != 0 && P_MAIN_ORDER != 0)
iTimer_Handle = NewAsyncTimer (0.2, -1, 1, CALLBACK_MAIN_Start_test, 0);
(1,679 Views)
You cannot operate this way: a contro ID (like e.g. P_MAIN_Operator) will never be 0!
You must retrieve the correct attribute (either the value or the index) for each control and check its validity accordingly. CVI offers a range checking facility and ValidatePanel () function that checks all controls in a panel that has Range Checking parameter in Notify mode, but it works only for numeric controls.
(1,668 Views)
And please try to not
open several discussions
on the same argument!
(1,664 Views)
I wanted to edit the questions I added but I found out it is not possible. I just reported them to the moderator to delete them.
Thanks a lot for the help 🙂
(1,651 Views)
