LabWindows/CVI
What is the best way to communicate between CVI and a direct PLC0450?
I used the OPC server aplication years ago and it was harsh. When it crashed and it often did it took out the PC totally. I want a device driver in CVI.
(2,838 Views)
OPC is the primary way CVI users talk to PLCs and is supported through our DataSocket library in CVI. If you don't want to use OPC, then you should contact your PLC manufacturer to try and get a DLL driver for the PLC that you can use in CVI.
Best Regards,
Chris Matthews
(2,838 Views)
