LabWindows/CVI
What is the best way to copy or move multiple files at once?
Hi all
Just curious if anyone has a good way of copying several files quickly...
I am using the utility library functions CopyFile and DeleteFile in a loop (along with Fmt to specify the paths) to copy a bunch of files (from a directory on a network drive to another directory on the same network drive) and this runs sloooww
There has to be a better way ,,,,or maybe a function that copies/moves several files at the same time 😉  Copying the same files via drag and drop in Explorer is quick!
(3,286 Views)
Are you using functions from the Utility library or from Windows SDK? I'm asking you because functions from the utility library accept standard wildcard characters '?' and '*' so you may be able to group files with similar filenames and process them in a single call.
Another hint could be to test SDK MoveFile function: it is possible that this function is faster than copying to a new file and deleting tha old one after. I never tried it but it may worth a try.
(3,280 Views)
