Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
What is the easiest way to add XML capability to LabWindows?
dmonty
Member
09-26-2002
08:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I would like to use XML to store config files and to generate reports. What is the best way to do this?
0
Kudos
Message
1
of 2
(3,489 Views)
Reply
Re: What is the easiest way to add XML capability to LabWindows?
bilalD
NI Employee (retired)
09-27-2002
11:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You could use the Microsoft XML Parser, it comes with a COM component that you can import into CVI via the ActiveX controller Wizard. You can download it from
here
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
0
Kudos
Message
2
of 2
(3,489 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
