LabWindows/CVI
What is the format for the functions used in labwindows/cvi in connect with field point?I have reinstalled the field driver, so it can det
ect cvi.I am trying to use the function options for the instrument,but I have trouble deciding on the components needed. I started with the open function;which variables must be used and what are the required buffers,etc? Using FP-1000 &FP-AO-200.Thank-youUsing LAbWindow/CVI and FIELD Point
(2,773 Views)
ect cvi.I am trying to use the function options for the instrument,but I have trouble deciding on the components needed. I started with the open function;which variables must be used and what are the required buffers,etc? Using FP-1000 &FP-AO-200.Thank-youHave a look at the examples in cvi\samples\FieldPoint. There are AO samples that will show you the function steps to take.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(2,773 Views)
