LabWindows/CVI
What is the relation between LabWindows events and Windows messages? (might explain hanging on mouse click)
Because of the requirements for my application, my application currently uses a message loop with three 'forks', used for communication with my TWAIN webcam, LabWindows controls and everything else (Windows, basically), respectively. For some reason, this does not work correctly.
Everything starts with a PeekMessage(PM_NOREMOVE) which fills a message structure but does not remove the message from the queue. For the TWAIN fork, there is no problem: TWAIN requires me to send every message to the Source Manager, which then tells me whether it was his or not. Depending on that answer, I either check for a new message (after removing this one) or continue processing the current one. If I continue, I call GetUserEvent, check to see whether it has removed the message from the queue (just to see if GetUserEvent actually did something with the message), and if not, I process the message the plain, old-fashioned Windows way: TranslateMessage() and DispatchMessage().
After noticing that my application would hang on mouse clicks (there would be no response after clicking a button, until I moved the mouse), I started wondering whether the LabWindows events would actually show on the message queue. After all, I was only running GetUserEvent if PeekMessage had found anything.
To check this, I changed my message loop to be like this:
while(!PeekMessage(no wait, PM_NOREMOVE))
    ProcessLabWindowsEvent();   //this is all I changed!
    WaitMessage();
if(!CheckAndProcessTwainMessage) //return value shows whether it was a TWAIN message or not, if it was, it has also been processed and removed from the queue
if(message has not been removed from queue)
    ProcessWindowsEvent
Sure enough, the response to a mouse click is now immediate. This has left me wondering: does this mean that LabWindows events are not windows messages (that is, not only is it impossible to process them with DispatchMessage, they aren't even stored on the message queue)? That would mean that there is a seperate LabWindows queue which has no relation whatsoever with the windows message queue.
To test this, I inserted code that would 'warn' me when GetUserEvent returned a nonzero value while the message queue was empty (I used GetQueueStatus for testing this), and some code that would 'warn' me when GetUserEvent had removed a message from the message queue (which is apparently the case when the topmost message has changed). To my surprise, both of these codes 'warned' me, which would mean that some of the events are (or correspond to) windows messages and some aren't (don't). Does anybody have some more information on this?
Also, it seems to me that the WaitMessage() would cause me to temporarily ignore LabWindows events if they should happen immediately after eachother without a TWAIN or Windows message between them, causing my application to hang again. So far, I have not had any problems with this. I guess the two events immediately after eachother are an improbable scenario?
Message 1 of 1
(3,405 Views)
