LabWindows/CVI
What object does TS_ReportReset require?
I am trying to use the function TS_ReportReset. It is not working when I try to call it though
local_err = TS_ReportReset (seqContextCVI, NULL, "Test", &NullReturn);
Am I supposed to use the sequence context or a different object handle?
(3,729 Views)
When you say that it's not working, what kind of error are you receiving?
Mark E.
(3,716 Views)
Thanks for the response. I did manage to find the solution though.
TS_SeqContextGetReport had to be called from the sequence context to get the proper object. An object browser for CVI would be a great improvement, even if the object could be reported as just one long text string.
(3,713 Views)
Steve, thank you for that feedback.  We appreciate customer feedback a great deal, and our R&D reviews all of them, so they're not going into a black hole.  You can make product suggestions at our Product Suggestion Center.  The more complete the description of the suggestion and how it would help you, the better.  Thanks!
Mark E.
(3,698 Views)
