LabWindows/CVI
When I add list to a data chain, the address of the previous pointer is changed and of couse I get a error while free it
The struct of the chain  as follows:
typedef struct _SHOW_DATA
    int GainStates;
    int ShowDataIsValid;
    struct _SHOW_DATA *pNext;
}SHOW_DATA;
typedef struct _DATA_CHAIN
 SHOW_DATA *pStart;
 SHOW_DATA *pWrite;
}DATA_CHAIN;
Add list function:
void DataChain_Add(DATA_CHAIN *pChain,SHOW_DATA *pshowData)
 if(pChain->pStart == NULL)
  pChain->pStart = pshowData;
  pChain->pWrite = pshowData;
  FirstDataIn = TRUE;
 else
  pChain->pWrite->pNext = pshowData;
  pChain->pWrite = pChain->pWrite->pNext;
pStart saves the starting pointer of the chain,pWrite pointer the end of the chain,using pshowData=malloc(sizeof(SHOW_DATA))  to add list 。When the list is not to long,pStart->pNext== 0x00FF3C20;the address is true,but as the list is longer,suddenly the address is changed,becomes 0x0000001E. So when I delete list,free the address 0x0000001E, of course I got a Error “attempt to free pointer to memory not allocated by malloc() or calloc()”.Who can help me?Thank you!!!
(3,281 Views)
please could you point out in how far this question is related to CVI? This is not a forum about the programming language C...Smiley Wink
(3,276 Views)
by the way, there NO need for multiple posts
(3,273 Views)
I am so sorry, I thought I Posted in the Chinese section cannot being seen in the English section.
I think it is the bug of  labwindows 2009,so I posted this question here. however ,I will continue to research this question
(3,267 Views)
