LabWindows/CVI
When applying a large array of memory overflow occurs, such as a [100000], how do
When applying a large array of memory overflow occurs, such as:double a [100000], how do?
(4,688 Views)
The stack cannot handle large arrays.
Allocate your array on the heap, using malloc(): http://stackoverflow.com/questions/5746377/allocating-a-large-5000-array
Certified LabVIEW Developer
(4,685 Views)
Alternatively, you can set the stack size in Build Options.
If your array size cannot be predicted previously the heap size suggested by JKSH is the best way to handle it. Remember to free the memory when you have terminated using it.
(4,662 Views)
