LabWindows/CVI
When starting CVI created program on Win 2000, I get message-Program Error.
When starting CVI created program on Win 2000, I get message “Program Error”.
I have created a program using NI/CVI version 7.1.1 and created distribution kit that will automatically install CVI libraries and RTE. On most computers XP and 98 program runs fine. On one computer, running windows 2000, I get message
“Program Error
Program_I_created.exe has generated errors and will be closed by Windows. You will need to restart the program.
An error log is being created.”
Please let me know if anyone else had this problem or knows solution.
Thank you very much.
Radovan
(2,787 Views)
Hello Radovan,
In order to troubleshoot this issue, could you provide more information on what your application is doing?  Are you doing communication, data acquisition, what features do you have on the user interface, etc?  Do you have CVI installed on the Window 2000 machine, if so, are you able to debug your application on this machine, and if you are able to do so, on which line of code does your application crash?
Thanks again.
Wendy L
LabWindows/CVI Developer Newsletter
(2,767 Views)
