LabWindows/CVI
When you develop a test prograam for the 4461-pxi and 4070-pxi using the method described in the Calibration Procedure documentation on the NI website, will it work if developed on cvi5.51?
I am trying to develop a calibration test for the 4461-pxi and 4070-pxi using the guidelines given in the documentaation on the NI website (NI446X Calibraaation procedure and the simaler one for the 4070).  I only have cvi5.51 available.  Will this work?
(2,959 Views)
Hi obrien,
Those functions should all be available in NI-DAQmx C API.  If you can get that working in CVI 5.5, then you should be good to go.
Most of those functions can be found in the NI-DAQmx C Reference Help (Start >> Programs >> National Instruments >> NI-DAQ >> NI-DAQmx C Reference Help) under the section NI-DAQmx C Functions >> Advanced Functions >> Calibration.
Thanks!
mike
(2,948 Views)
