LabWindows/CVI
Where I can find the file cvi_db.h?
help me!!!!!!!!!!!
Somebody that says to me where I can find the file cvi_db.h, without this file I cannot make connection to my data base in CVI
please....
(5,102 Views)
Hi Gato,
The cvi_db.h and lib file come with the SQL toolkit. If you already have this installed, the libraries should be available for you in CVI. If it is installed on a previous version of CVI on this machine, you can copy the \sql20 directory into the new version of CVI and then you should be able to use it. The header and library are found in the \sql20\ directory.
Hope this helps!
Good luck and thanks for using NI forums.
Arturo Vargas
National Instruments de México
(5,092 Views)
