LabWindows/CVI
Why I cannot run the writer program of datasocket CVI?
I am now writing a program about the writer of datasocket in CVI. The aim of the program is plot a graph with random value and then send the graph out through datasocket server. It showed "active:connected" if I use PlotStripChartPoint to plot the graph. But when I use PlotStripChart, it doesn't success. So what is the difference between them and if I wanna use PlotStripChart to plot graphs, how should I modified the program ?
Thx a lot for every one who had read this question.
(2,926 Views)
I tried to run your code, but it didn't compile because of type conflicts.
Any way, what error do you get when you use PlotStripChart? Am I correct that you are trying to plot the data in the datasocket reader program, and the data was sent by your writer program?
(2,926 Views)
