LabWindows/CVI
Why can't I link another vendor's library into CVI Linux?
I have built an application under Linux using the CVI Run Time version 8.0.  I now need to add functions to control a third party vendor's hardware.  I included the vendor's header file and compiled with CVI on Linux machine.  I used the -l option with cvicc to link with library libdscud5.a provided by the other vendor.  When cvicc hands over to gcc I get the error "cannot find -libdscud5.a".  The library is in the /lib directory as well as in the /usr/lib directory with the cvi libraries.  Why doesn't this work?  I tried using -llibdscud5.a and -libdscud5.a with the same effect.  gcc is version 4.2.2.
(3,140 Views)
Use -lscud5
The prefix lib is assumed as well as the suffix .a or .so
Michael
NI
(3,132 Views)
Thanks.  That's what it needed.  Seems obvious to me now.
(3,128 Views)
