LabWindows/CVI
Why do I get a library function error when running system()?
I am running a DOS program through a system() command from within a CVI program in CVI 2010.
It works on my laptop, but on my PC it crashes with a library function -3 error.  Why is that?
thanks,
Joel
(3,551 Views)
As you can see in the online help, return code -3 stands for "File not found": it could be that you are passing a wrong pathname to the function.
(3,548 Views)
The function panel help says:
-3 File was not found.
I guess you did allready check that this command exists on your PC.
How do you call that command ? With full path ? Or just the command? Then there may be differences in $PATH.
(3,547 Views)
Thank you for your courteous answers.
joel
(3,532 Views)
