LabWindows/CVI
Why does fopen "w" throw a FileExists error?
I am programming in CVI for Real Time.
The following line is throwing a File Exists error even though "w" is supposed to wipe the file contents and write a new file.  This doesn't happen on another controller of mine.  Any ideas?
InputFile = fopen("c:\\\\DDRT\\Configuration\\DDRTRunNumber.txt", "w");
throws:
NON-FATAL RUN-TIME ERROR:   "DDRT.c", line 3250, col 14, thread id 0x00000096:   Function fopen: (return value == 0 [0x0]). (EEXIST) File exists
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(3,726 Views)
Hi Michael,
When you open the file after that error do you see that the contents of the file have been wiped and replaced?
(3,692 Views)
I found the reason but I need to know why...
I have a RT PXI system and I have to reference files with "C:\\\\....."  I don't know why the string is essentially C:\\
I have a loaner unit that is dual boot.  I'm running it in RT and I only need "C:\\...."
Why the difference?  Both are supposed to be running LabVIEW RT 14.0.  Do they have different RTOSs?
Thank you.
(3,687 Views)
Can you verify that both your controllers are running LabVIEW RT 14.0 through NI MAX? Thanks.
(3,670 Views)
The monitor shows "Welcome to LabVIEW Real-Time 14.0" on the display signal coming from the PXI system.
MAX says LabVIEW Real-Time 14.0.0
(3,665 Views)
What are the models of both controller units?
(3,654 Views)
