Hi hendra,
This is almost certainly due to a bug in the installer that was found and corrected since the last release. See
this thread for more details. Basically, you should avoid running setup.exe from a path that begins with the path to an existing app. That is, don't run your installer from C:\Foo\Bar Baz\...\setup.exe if C:\Foo\Bar.exe exists. If you do, that app will be run twice during installation.
The fix will ship with the next release of CVI, and has already shipped with many drivers in the second half of this year. I've put a distribution containing the fixed component up on NI's ftp site. Just go to
ftp://ftp.ni.com/outgoing and look for TestMDFSupportDistribution.zip. Unzip the files, then run setup.exe, and you should be all fixed up.
As for the reboot prompt, this is normal behavior. If any of the drivers/components included in your distribution require a post-installation reboot, you will see this prompt. You may also get the prompt for other reasons, such as importing a MAX configuration file as part of your installation.
Let me know if I can help further.
Mert A.
