LabWindows/CVI
Why does the agilent 34980a ivi-c driver not have parameter information for labwindows use. Can it be added to the prebuilt DLL.
Why does the agilent 34980a ivi-c driver not have parameter information for teststand/ labwindows adapter  use. Can it be added to the prebuilt ivi-c DLL.
In the past I have rebuilt the driver with the source code , but this driver dose not have the *.c file in the source. Only the IVI-com .cpp file are present
(2,961 Views)
Hi gerberf58,
That driver is written by Agilent.  You may be able to get the source files you need from them.
Brandon V.
Applications Engineering
www.ni.com/support
(2,936 Views)
