LabWindows/CVI
Why doesn't const int work?
The piece of code below should compile.  It does not.  Looking at several C++ books it claims that is shoud.
Any ideas.  Thanks.
the old vax guy.....
const int stack_size = 45;
double   stack[stack_size];
void main(void)
stack[0]=0;
(3,220 Views)
LabWindows/CVI is strictly based on ANSI-C and although C++ might allow a variable to be used in array initialization, ANSI-C does not permit this.
If you want to declare an array in C, you need to use a constant expression (an actual number or a #define constant defined to a number).
Ludek
NI
(3,211 Views)
Ipekarek.
Thanks for the answer.   NI also answered with the fact that CVI follows the 89 ansi-c standard not the 99 ansi-c standard.
Also, I'm using #defines.
Thanks again.
the old vax guy.
(3,185 Views)
