LabWindows/CVI
Why is CVI 7.0 C compiler NOT ANSI compliant
The following code segment works in an ANSI compliant compiler:
char argbuf[500];
int respSize;
char *pTitle, *msgText;
sprintf (argBuf, "[%*s][%s][%s]", respSize, " ", pTitle, msgText);
At runtime CVI ignores the field width argument (respSize) and then tries to use it as a char * argument.
(3,569 Views)
The code you attached should work, and it works in my computer. I tried running this in the interactive window:
#include
static char argbuf[500];
static int respSize = 10;
static char *pTitle = "title", *msgText = "message";
sprintf (argbuf, "[%*s][%s][%s]", respSize, " ", pTitle, msgText);
...and at the end, argbuf contains the following value:
"[ ][title][message]"
What happens when you run it? Do you get a runtime error complaining about respSize? What is the exact error message?
By the way, I noticed that the you have a typo in the first argument to sprintf (argBuf vs. argbuf). Is it possible that the error could be referring to this?
Luis
NI
(3,570 Views)
The problem is that there should be 10 spaces between the first set of brackets; the * in the first conversion specification indicates that respSize is supposed to specify a minimum field width.  See: http://man.he.net/?topic=sprintf&section=all
I'm replying to this old post because I'm about to link to this post in a new one with a similar question.
(3,382 Views)
On my machine (Win XP Pro SP2) Luis code gives expected results (including the 10 spaces between the first two brackets).
Tested on:
CVI 6.0.0 (105)
CVI 7.1.1 (313)
CVI 8.0.1 (356)
(3,373 Views)
