LabWindows/CVI
Why tscvirun is suspended?
I'm running my code in CVI 8.0.1 in debug mode.  I put a break at the end of the function called from TestStand and it get there ok.  Then, when I do F5 (to resume...) the run is suspended.  I need to hit the F8 about 4 times for the procedure to end and get back to the TestStand.
Why is it suspended?
How can I see if there's a condition set to break the run?
How one can reset all the break conditions that might still be there?
Rafi
(3,025 Views)
Rafi,
Which version of TestStand are you using?  I'm a bit confused... are you calling into the code from TestStand or are you simply running the code in the CVI environment?  If you are calling into the code from TestStand, am I correct to assume that you have modified the Adapter options for the CVI Adapter in order to run your step in an external instance of CVI?  Lastly, have you included the TestStand/CVI Run Support source file?
Derrick S.
Product Manager
NI DIAdem
(2,963 Views)
