LabWindows/CVI
Will C code work in LabWindows/CVI?
I have some example code I am trying to work from that is in C++. Will this work in LabWindows/CVI.
(3,565 Views)
yaa it will work, whatever is in C , will work in CVI labwindows, because CVI uses Ansi C complier.
(3,565 Views)
(3,565 Views)
However, C++ will not work without an external compiler.
-John
(3,565 Views)
Thank you, that's what I needed to know. (The "C++" did not show up in the question heading.)
-Dan
(3,565 Views)
