LabWindows/CVI
Will Mocrosoft C/C++ Header file(s) work in LabWindows/CVI?
Is there a way to get Microsoft based Header(s) files to compile in LabWIndows/CVI.  It appears that LabWindows/CVI does not like the words "BOOLEAN" or "HANDLE" in the header file for an example?
Is there a switch that I need to set in LabWindows ENVR to accept this MS C/C++ Header files?
(4,284 Views)
HANDLE is defined in cvidef.h as a pointer to void.  cvidef.h gets pulled in with most any CVI header file, such as utility.h or userint.h.  Or just include cvidef directly.
BOOLEAN isn't a defined type in CVI but BOOL is defined as an int, also in cvidef.h.
If you're using windows.h, include that before any of the CVI header files.
Menchar
(4,282 Views)
Menchar, thanks it worked.  I am off on CVI Data Types at 8:36 pm..
(4,268 Views)
