LabWindows/CVI
Wiltron 54147A Network Analyser
Having problems with programming the 54147A using CVI.
When trying to use the "OCC" and "OCD" commands to store the calibration settings and then the "LCC" and "LCD" to get the analyser to learn from the stored binary data file, the analyser gives a syntax error and fails to learn from the file.
The programming manual is not very useful and Anristu very unhelpful as this is not on their current product list.
Any help would be gratefully received.
J
(3,296 Views)
Hi John,
I have no experience with this instrument, but the community might be able to help if you can post the OCC, OCD, LCC and LCD syntax commands from the programmers reference manual as well as the CVI commands you are using to talk to the instrument. We might be able to find the syntax error that is being reported.
Bear in mind that the fault might not lie with the command to learn from the stored file, but from the file you tried to save earlier, so also focus on those code segments.
I wish I could offer more help initially, but hopefully we can help with your response to this post.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(3,235 Views)
