LabWindows/CVI
Win10 32bit Low-Level Support Driver
I need to read from IO space addres 0x700. I try to work with 'Low-Level Support Driver'. The driver dosn't load.
The function CVILowLevelSupportDriverLoaded () return '0'.
How can check if the driver installed on my PC and if not, how can I install it.
(1,938 Views)
Hi, take a look at this manual page, it says 3 things:
  • It can be operated only on 32-bit systems
  • It must be specifically installed with a custom CVI install
  • You must run your application with administrator privileges to use it
Having said this, however, look also at this discussion and carefully consider responses from RolfK.
(1,919 Views)
