LabWindows/CVI
Windows XP supports Labwindows/CVI Test Executive 2.01?
Is Windows XP supports Labwindows/CVI Test Executive 2.01? If no, any patch SW available to make work it on Win XP?
(3,142 Views)
We have run cvi Test executive on Win 2000 and XP  we used CVI 7 to build the exe.
not sure if an existing exe  compiled for an earlier version of  windows will work.
Note  with the later versions of OS come  multiprocessor support we have had some issues with programs written for single processor operating systems crashing after a few hours when running on a multiprocessor system. This was fixed by setting the processor affinity  to restrict the application to a single processor  ( under task manager go to process  right click and select set affinity then only tick one of the processors.)
Colin
(3,132 Views)
Thanks Colin. Will try build exe with latest CVI version.
As you mentioned, existing exe built using CVI 4 & Win95 is NOT working with Win XP.
Dhilip
(3,104 Views)
