LabWindows/CVI
Windows error message "The memory could not be "read" " upon exiting an application
AndreasC wrote:
I got the same problem with an LabView application built with 8.6.1 but not with 8.5.  The exe works very well until the EXIT-function. Other selfmade applications doesn't have this.
I use only the database connectivity functions in all apps.
Any idea?
Andreas
Unfortunately none Smiley Sad
Boti
Message 11 of 12
(1,170 Views)
AndreasC,
You may want to start another thread and reference this one, did you follow some of the above troubleshooting steps? If so, what was the outcome?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
Message 12 of 12
(1,151 Views)
