LabWindows/CVI
Word2000.fp
El instrumento para reports Word2000.fp tiene muchas funciones, todas ellas sin ayuda en el entorno de CVI. ¿Dónde puedo encontrar descripción detallada de cada una de estas funciones? Gracias.
(5,191 Views)
¡Hola!
Tal vez este documento pueda serte de utilidad:
Error Displaying Microsoft Office 2003 Help Documentation in LabWindows/CVI
Otra informació puede ser encontrada en este otro documento: aunque se refiera a LabVIEW creo que pueda aplicarse al CVI también:
Excel or Word Help Files Not Working from LabVIEW 6
(te recomiendo que escribas en inglés en esta tabla internacional. Hay otra tabla para ispanohablantes aquí )
English translation:
This document could help:
Error Displaying Microsoft Office 2003 Help Documentation in LabWindows/CVI [broken link removed]
Other informations can be found in this other document; even if it refers to LabVIEW it can probably apply to CVI as well :
Excel or Word Help Files Not Working from LabVIEW 6 [broken link removed]
(5,178 Views)
Thankyou Roberto:
The links look very usefull; I will take a little time to try these solutions, cause a new "fire" has arised, but I'm willing to come back to this issue. I will post back results.
Sorry for the language I'm new to this forum.
Best regards.
(5,153 Views)
No problem for the language Smiley Wink
I hope you will find a solution in the links I posted: the only other source of informations is the Microsoft site; interfacing with ActiveX is a bad beast, but digging in this site you can find several examples and forum posts that may help you.
You may also consider to use the Word Report instrument, which is more aimed to generating reports and is a bit simpler and more documented.
(5,149 Views)
As a matter of fact I am actually using the Word report instrument and works excelent. I also use LibHaru PDF to generate PDF, as my application generates reports both in Word and PDF formats. I also find Libharu excelent and I am doing very neet reports. The problem is using my application with Word 2010. This version of Word reacts in a different manner than earlier versions.
For example tables generated in a doc with the simpler Word report instrument do not have the same effects in Word2000 as they have in earlier versions. I've read something about this issue and it seems to be a very well known issue; I belive that the more complete version of the instrument, this is the Word2000.fp instrument, will deal better with different versions of Word. ¡I hope!.
(5,145 Views)
