LabWindows/CVI
Working with Hi Baud Rates Via 422/485
Hi all ,
I'm working with CVI 9.1 and i have 2 PCI Cards :
Advantech PCI Serial port - RS232
FastCom Async PCI-335 - RS422 / 485
I know there is basic serial com lib which contains RS232 Funcs , i also know that those funcs work well with 422 / 485,,,
My problem or Question is that i need to use 6M baud rate which reflects 50MH There is no option to chose this Baud rate at the rs232 func , if i'll enter it manually will it work ?
Or maybe there is an 422 / 485 lib ?
Thank You
Kobi Kalif
Software Engineer
(3,418 Views)
Accepted by topic author Kobi_K
You will need to set the FastCom board clock generator to a non-standard frequency. The manual for the card explains how to do this by using Windows API IOCTL function calls. There are also example programs on the CD supplied with the card.
Martin
Certified CVI Developer
(3,410 Views)
