LabWindows/CVI
Working with multiplie Panels And C Files
Hi !
I have a general question...
I'm workign with CVI 9.1 , and i have serveral C files .
At the main.c file I'm loading all my panels for ex Panel Name - PREF, Panel Handle - panelPrefHandle
At the service.c file I'm trying to use GetCtrlVal(panelPrefHandle,....,...);
                                              OR  GetCtrlVal(PREF,....,...);
At service.c i'm including #include "main.h"
Still I'm getting the error :
NON-FATAL RUN-TIME ERROR:   "Service.c", line 677, col 29, thread id 0x00000D30:   Library function error (return value == -42 [0xffffffd6]). The handle is not a panel handle
so my question is how can i pass panel handel over serveral c files ?
Kobi Kalif
Software Engineer
(3,490 Views)
you need to include the include file of the panel: if you build and save a panel in the UIR editor, a corresponding *.h file is generated; you need to include this file in the *.c file which will access this panel, because the panel name etc. are defined in the panels' include file.
Hth, Wolfgang
(3,485 Views)
I know thats what i did .
But still it doesn't recognize the panelHandle
Kobi Kalif
Software Engineer
(3,482 Views)
See here.
JR
(3,476 Views)
Declaring you panel handle as a global works, you can also just pass the handle to the function as an integer:
yourFunction(int PanelHandle)
and use it inside your function as needed.
(3,458 Views)
