LabWindows/CVI
WriteFile in ASCI mode writes a CR CR LF if I pass a CR LF.
(4,566 Views)
Taken from online documentation for OpenFile (File Type parameter):
fileType
integer
Specifies whether to treat the data in the file as ASCII or binary. When you perform I/O on a file in binary mode, carriage returns (CR) and linefeeds (LF) receive no special treatment. When you open the file in ASCII mode, each CR/LF combination translates to an LF when reading, and each LF translates to a CR/LF combination when writing
WriteLine does not need any line feed at the end of the string since it appends the correct line termination itself. Since you are appending a CR/LF at the end of your string, the last LF is translated to a CR/LF thus resulting in what you are seeing. Try adding anything to the string.
Message Edited by Roberto Bozzolo on 05-16-2007 07:10 AM
(4,550 Views)
I am getting the data from 2 differant sources 1 has CR LF, 1 has just LF.  Do you think it would work to use both ASCII or Binary writes for the differant data sources to the same file?
(4,531 Views)
Couldn't you simply remove any CR/LF character prior to pass the string to WriteLine?
(4,514 Views)
