LabWindows/CVI
Writing CR Character to port
Hi ,
I have a problem with a Simple RS232 Port...
Is there a function that writing CR termination to a serial port ?
I know i can simply write 13 DEC to the port just wondering if theres any thing build in for the cvi....
Kobi Kalif
Software Engineer
(3,119 Views)
if you happen to use VISA you could use viSetAttribute ( session_handle, VI_ATTR_SEND_END_EN, ) and define VI_ASRL_END_TERMCHAR; this way the terminating character is automatically appended
(3,115 Views)
This does a string with CR at the end pretty well in an old version of labwindows:
Fmt(send_cmd,"%s<%c%i%s\r", SENDESC, i + 1, LIMITCOM);     //this  adds 1 to i  so send_cmd starts at 1L - Type of slot request
and then:
stringsize = StringLength (send_cmd);
    bytes_sent = ComWrt (COMPORT, send_cmd, stringsize)
Of course this is a char string: <ESC>1L<CR>.  Have a look at the serial.prj example for single bytes.  - NB both SENDESC and LIMITCOM are #defines with SENDESC 27 and LIMITCOM  "L"
Steve
(3,096 Views)
