LabWindows/CVI
Wrong file name received by my application
When a file with the extension *.log_c is double-clicked, it is automatically opened by my application (I acheived this by adding some registry values). The pathname of the opened file is then received in the variable argv[1] of the main function of my application. However, on most systems it seems that the string I receive is not the same of the pathname, but some abbreviation that reminds me of DOS, where a file name or a directory could only be 8 characters, and a file extension could only be 3.
E.g: when I open the file C:\Documents and Settings\Wim\My Documents\LabWindows\DebugLogDecoder\dbg_20060621_114839.log_c, the string that I receive is C:\DOCUME~1\Wim\MYDOCU~1\LABWIN~1\DEBUGL~1\DBG_20~1.LOG
This problem occurs on some machines. On other machines argv[1] contains the correct pathname.
Why is that and how can I solve this problem?
Thanks for all help,
Wim
(3,265 Views)
Wim, the reason why on some system the long file is passed to the program and on some others the short one will probably reside in some non-evident option of Windows Smiley Sad that I don't know at present.
However, GetLongPathName windows API should help you to retrieve the long file name associated to the received command-line parameter.Smiley Wink
(3,262 Views)
Hello Roberto,
thanks a lot for the info, I will try it immediately.
BTW:  congratulations with your 1000 posts! You have been helping me out since the day I discovered this forum. I really appreciate it Smiley Wink
Message Edited by Wim S on 06-21-2006 03:03 PM
(3,258 Views)
OK, this works great. Thanks a lot!
(3,250 Views)
I'm happy to have helped you! Smiley Happy
(3,246 Views)
