LabWindows/CVI
Wrong image display under windows 2000 ?
hello,
I'm using CVI 5.0 under windows 2000 and a function using bitmap drawing in canvas which was working fine under windows 1998 has problem under windows 2000.
The problem starts when I draw my image with a zoom factor different from 1. My images are 8bit greyscale and their display seems to show a low depth resolution.
Any Idea ?
thanks
ArnO
(3,260 Views)
Arno,
I have been able to reproduce your problem and we will be looking into it. I have had slightly more sucess loading color bitmaps so you may want to investigate this as a workaround.
If you need further information on this please call or write in to NI applications engineering.
Amaury R.
-National Instruments
(3,260 Views)
I had a problem associated with a picture I had embedded in a panel. The image was garbled but when I lowered my display resolution from 32bit to 16 bit the image would display correctly. The funny thing was it would display correctly at 32 bit as well until I rebuilt the uir with the display set to 32 bit. I am running cvi 6 and win2k.
(3,260 Views)
