LabWindows/CVI
XModem Transfer in LabWindows
I can successfully execute an XModem file transfer between a PC running a
LabWindows application an a standalone PC at 9600 Baud. If I increase the
baud rate on both machines above 9600 baud, other serial transfers still
work, (ComRd, ComWrt) but XModem transfers time out. Any suggestions?
(5,424 Views)
can you send your .vi files??? ... i need tranfer files over serial port and xmodem ... plz
at nemesisx666@hotmail.com????
Mensaje editado por nemesisx666
(5,162 Views)
Hi Mike,
Have you tried running NI-Spy to capture what is happening when the code is running?  Also - try increasing your timeout, you may not be giving the instrument enough time to respond.
Please let me know if you have any other questions,
Meghan
(5,114 Views)
Meghan,
I hope that Mike has resolved this my now, this thread was started in 1999.
nemesisx666,
If your looking for .vi 's you want to try reposting your question in the LabView forum.  This is the LabWindows forum.
Good Luck!
(5,109 Views)
Thanks mvr,
I should be paying better attention!  Guess I was living in the past 🙂
Meghan
(5,075 Views)
