LabWindows/CVI
XY graph using formula node
In a formula node there is one input(x) and two outputs(y1,y2).
Plot y1,y2 on a single XY graph for different x1 values(from 100-200). please reply...
regards,
jathin
(3,740 Views)
Formula nodes are typical for LabVIEW, not so much for C Smiley Wink You probably should repost your question in the LabVIEW forum...
(3,736 Views)
...continued and solved here
(3,729 Views)
