LabWindows/CVI
Yaxis Sync on Graph
Hi i would like a little help..
I have a graph were i'm plotting some points..
I use both (left and right)Yaxis..
The left yaxis is showing the real position of the point (based on CVI's ZeroPoint) and the right using an offset. what i want is the right Yaxis to show always the point with an offset value (e.g 5).
lets see an example..
PlotPoint(...,x,y);
SetGraphCursor(...,x,y);
now the cursor horizontal line is showing the y value on the Left Yaxis and y+5 on the right yaxis.
off course i want to zoom and pan with no problems and i would like o be able to use auto scale for the new points how can i do this..?
i managed to make this using ATTR_ACTIVE_YAXIS attribute and ATTR_ACTIVE_YAXIS but when i add new points to the graph they dont scale equally so the right Yaxis (offset) is not correct..
(3,263 Views)
Hello karpa,
If I'm understanding you correctly, you want the right y-axis to always have the same min/max as the left y-axis, but with an offset of 5, so that its markers always show a value 5 points higher than those of the left y-axis? And you have the left y-axis autoscaling to the data that you're plotting?
If the problem you're having is that each time you plot, the left min/max of the left y-axis changes, and causes the two axes to be out of sync, why couldn't you, after every plot, programmatically get the min/max of the left y-axis (using the GetAxisScalingMode function) and then set the min/max of the right y-axis accordingly (using SetAxisScalingMode)? Does that make sense?
If this is what you want to do, you have no need to use ATTR_ACTIVE_YAXIS, since all your plots and cursors would be associated with the left y-axis.
Luis
(3,251 Views)
Thanks Luis it seems to work ok..
(3,202 Views)
