LabWindows/CVI
Zebra printer TLP 2844
Hello.
I need to print a serial number using the zebra printer TLP 2844. I am connected through USB because I don't have Serial port nor parallel port.
I have been able to print my serial number using the Zebra printer tools (see the screen shot for more details) with the EPL Commands :
"N
B30,0,0,1,1,20,60,N,"13.10.123456.123456"
P1"
But now, I don't know how to do to send these EPL commands inside my CVI application ?
Thanks a lot.
Yvan
(7,246 Views)
Try by creating a plain text file with the command to be print and send it directly to the port. For example, using LPT1 you would need to write a command line like this: copy NameOfFile.ext LPT1. Try it for your COM Port.
There is "No C" in spanish.
If you can think it, you can develop it.
(7,239 Views)
Hello.
Thanks for your answer Victor.
Unfortunately, as I wrote. I don't have parallel port nor com port in my PC.
So the only way I can drive this printer is by USB....
(7,226 Views)
You can use VISA to communicate via USB
(7,219 Views)
Accepted by topic author YPO
Flllow the instructions in the attached link.
https://support.zebra.com/cpws/docs/usb/dos2usb.pdf
Do not forget to give some kudos.
(7,212 Views)
Thanks a lot Victor.
It works well !!
(7,206 Views)
