LabWindows/CVI
Zoom a bitmap in canvas(cvi 7.0)
If load a bitmap into canvas , can just zoom the image object itself but not change the canvas ?
David
(3,539 Views)
You can, but you have to keep redrawing the bitmap each time you want to zoom. By manipulating both the source rect and destination rect that you pass to the CanvasDrawBitmap function you can zoom the bitmap. Having said that, you'll probably find that the results are less than desirable, since zooming the same bitmap again and again will not let you see a region of interest any more clearly. It will only make it more distorted.
Luis
NI
(3,539 Views)
Hello David,
Also check out this example program from our website.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3F0E356A4E034080020E74861&p_node=DZ52148&p_source=External
Thanks!
Wendy L.
Wendy L
LabWindows/CVI Developer Newsletter
(3,539 Views)
