LabWindows/CVI
Zoom along one axis only ?
I love the new (?) zooming abilities in graphs.
But is it possible to zoom along one axis only. If I have for instance a plot with a lot of points
along the X axis, I don't necessarily want the Y axis to enlarge...
Guillaume Dargaud
http://www.gdargaud.net/
"Everything should be made as simple as possible, but not simpler." - Albert Einstein.
(2,878 Views)
what you could try is, use the SetAxisRange function, along with the GetActiveGraphCursor (of course you will need a cursor on your graph). Just set the x axis range to zoom with the click of the cursor.
Also, if you did not want the cursor to be visible, you can make it transparent.
hope that helps.
Derek
(2,878 Views)
