LabWindows/CVI
about "#pragma comment"
Dose the CVI support "#pragma comment" now? when i use this command, the program dose not report any message, but not include the lib too.
(4,346 Views)
Please refer to the following links about "#pragma comment":
http://ae.natinst.com/public.nsf/web/searchinternal/620a22abb2ba8148862570b70077aeef?OpenDocument
(4,298 Views)
Hello jennygo,
your links seems not to work...
(4,293 Views)
Pragma is a standardized form of comment which has meaning to a compiler. It may use a special syntax or a specific form within the normal comment syntax. A pragma usually conveys nonessential information, often intended to help the compiler to optimize the program.
See page 1-4 of the LabWindows/CVI Programmer Reference Manual for more information on using pragma comments in LabWindows/CVI.
Here is the Link of the reference manual :https://www.ni.com/docs/en-US/bundle/323643a/resource/323643a.pdf
(4,280 Views)
hi,
    i read the pdf and don't find any about "pragma comment".  do you sure this command work in CVI? i think this command does not work in CVI.
(4,265 Views)
(4,253 Views)
