LabWindows/CVI
about timing loop and GUI control
Hi all,
  I have a code with two buttons placed on the panel, one is RUN, another is STOP. Initially, STOP is disabled and when I kick RUN, the STOP will be disable. But when STOP is  kicked, the RUN will be activated.
#include "testimg.h"
#include <windows.h>
#include <utility.h>
#include "asynctmr.h"
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include <NIDAQmx.h>
#include "toolbox.h"
static int panelHandle = 0;
static int stoprun = 0;
int main (int argc, char *argv[])
	int error = 0;
	nullChk (InitCVIRTE (0, argv, 0));
	errChk (panelHandle = LoadPanel (0, "testimg.uir", PANEL));
	SetCtrlAttribute(PANEL, PANEL_STOPBUTTON, ATTR_DIMMED, TRUE);
	errChk (DisplayPanel (panelHandle));
	errChk (RunUserInterface ());
Error:
	if (panelHandle > 0) DiscardPanel (panelHandle);
	return 0;
int CVICALLBACK MainPanelResponse(int panel, int event, void *callbackData, int eventData1, int eventData2)
  if (event == EVENT_CLOSE) QuitUserInterface (0);
  return 0;
int CVICALLBACK RunButtonResponse (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
  if (event==EVENT_COMMIT)
	int N=20;
	stoprun = 0;
	SetCtrlAttribute(panel, PANEL_STOPBUTTON, ATTR_DIMMED, FALSE);
	SetCtrlAttribute(panel, PANEL_RUNBUTTON, ATTR_DIMMED, TRUE);
	for (int i=0; i<N; i++)
	  // some heavy task
	  // here I use Sleep instead
	  Sleep(5000);
	  ProcessSystemEvents();
	  Sleep(2000);
	  if (stoprun>0) break;
	SetCtrlAttribute(panel, PANEL_STOPBUTTON, ATTR_DIMMED, TRUE);
	SetCtrlAttribute(panel, PANEL_RUNBUTTON, ATTR_DIMMED, FALSE);
  return 0;
int CVICALLBACK StopButtonResponse (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
	stoprun = 1;
  return 0;
My code is designed so to repeat a operation for N times after the START button is kicked. And if STOP button is kicked before the task is finished running. Stop the current application and return false; I wrote the code but it seems doesn't work. It seems that the application cannot be interrupted before the completete of the task. I don't know what's wrong with my code. If you have any experienence with that, could you please tell me what's wrong with my cdoe? Thanks.
(4,325 Views)
Accepted by topic author PKIM
What you are seeing is the expected behaviour: in your loop inside the run button, you have a 5 seconds wait in which the system is frozen, next another 2 sec with the system frozen again. For simulation puroposes you should modify the code this way:
double tini;
tini = Timer ();
requestToStop = 0; while (Timer () - tini < 5.0 || requestToStop) { ProcessSystemEvents (); sleep (50); }
The Stop button then must raise a global variable that stops the loop (requestToStop in my example above).
In actual code, such a long lasting process should not be handled inside a control callback: you should place it elsewhere depending on how you want to structure your code so to leave the UI responsive. Available alternatives are:
- A UI timer callback
- An Asynchronous timer callback (similar to the preceding one but executed in a separate thread)
- A separate thread issued with CmtScheduleThreadPoolFunction
Whichever is the solution, the stop button must be handled inside the code by raising a signal that let the processing stop in a secure manner.
(4,322 Views)
