LabWindows/CVI
access pci configuration space
I need to access the PCI configuration space for a PCI card. How do I find the config space using LabWindows?
(3,093 Views)
You can find some good resources on driver programming in C on the web.
jungo.com provides you with utilities that create skeleton code for you, this should help you start you up. And since this is just C programming, it should work in CVI, just like any other C compiler.
Hope this helps
Bilal Durrani
Bilal Durrani
NI
(3,093 Views)
Sure it will work, but I wonder if that is the way to go. What about using VISA, PXI...
(3,093 Views)
