LabWindows/CVI
actively remove unwanted characters
Hi, I'm writing a function to actively remove unwanted characters from an input field. It will run every time a key press event occurs on the selected input fields. It is going to remove quotes and things like that. This is what I have so far..
void test(){
	char unwantedCharSet[50]={"abcD"};
	char tempString2[200];
	int matchedCharIndex;
	GetCtrlVal (panelHandle[MAIN], MAIN_STRING,tempString);
	do{
		RemoveSurroundingWhiteSpace (tempString);
		matchedCharIndex = strcspn (tempString, unwantedCharSet);
		if(matchedCharIndex==strlen(tempString)){
			SetCtrlVal (panelHandle[MAIN], MAIN_STRING, tempString);
			return;
		else{
			strncpy (tempString2, tempString, matchedCharIndex);
			CopyString (tempString, matchedCharIndex, tempString,matchedCharIndex+1,(strlen(tempString)-matchedCharIndex));
			strcat (tempString2, tempString);
		sprintf(tempString,"%s",tempString2);
	} while(1);
return;
It is still glitchy. Does anyone have any advice to efficiently do this?
Thanks in advance!
(3,754 Views)
did you consider using regular expressions, via RegExpr_FindPatternInText ?
(3,749 Views)
Thanks, thats a good one to remember. (I'm still very much in a learning phase)
I'm also trying to use what Al S suggested here.
void test(){
	char otherString[50];
	GetCtrlVal(panelHandle[MAIN],MAIN_STRING,tempString);
	filter(tempString,otherString);
	SetCtrlVal(panelHandle[MAIN],MAIN_STRING,otherString);
return;
int filter(char *inputString, char *outputString){
	int inputPtr, outputPtr = 0;
	for (inputPtr=0;inputPtr<strlen(inputString);inputPtr++,outputPtr++){
		if (inputString[inputPtr]==41||inputString[inputPtr]==30){
			inputPtr++;  // increment the inputString pointer to skip the backspace
			outputPtr--; // decrement the outputString pointer to overwrite
  		outputString[outputPtr]=inputString[inputPtr];
	outputString[outputPtr]='\0';
return 0;
(3,746 Views)
Accepted by topic author TurboMetrologist
This was my solution, although, it takes a long time to perform. Does anyone have any tips on a better (faster/cleaner) approach?
//  TEST
void test(){
	SetCtrlVal(panelHandle[MAIN],MAIN_STRING,filter(tempString,unwantedCharSet));
return;
//  FILTER
char *filter(char *inputString,char *filterString){
	int ptr=0,matchedCharIndex=0;
	char outputString[100];
	do{
		matchedCharIndex = strcspn (inputString,filterString);
		if(matchedCharIndex!=strlen(tempString)){
			strcpy (outputString, inputString);
			for(ptr=matchedCharIndex;ptr<=strlen(inputString);ptr++){
				outputString[ptr]=inputString[ptr+1];
				DebugPrintf("%s\n",outputString);
				if(outputString[ptr]=='\n'||outputString[ptr]=='\0')
					break;
			strcpy(inputString,outputString);
		else
			return inputString;
	} while(1);
return inputString;
(3,723 Views)
