LabWindows/CVI
activex "find" command in Internet Explorer 5.0
Have looked thru Activex functions for Internet Explorer 5.0 and cannot determine if a command exists for the "find" function in internet explorer. Has anyone figured this out
to control the find command and enter the find text using activex for Internet Explorer 5.0 ? Found every other command but this one.
cvier
(3,029 Views)
Hello cvier,
From searching online and MSDN, you need to use the TextRange object to create a range of text then search through this range for a specified string. More information can be found on the following website and the object model can be found on MSDN.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,007 Views)
