LabWindows/CVI
activex server
i have a few questions about Activex Server. I am newly with Labview CVI, and i want to create a Activex Server or a DLL. I looked at Examples, and i want to do as same as what it is in Examples.
For Example: Datatypes Server.prj.
i did, what i see in this example, and wizard had created test_axs.h, test_axs.h, test.axs and test_axs.idl.
my question is, should i create a C source code?
Because in this example Datatypes.c File existiert.
must i write my own C code, or, Labview CVI creates it?
why i am asking this,because it gives error, for ex. "Undefined symbol '_testOBJtest1LongScalar@8 referenced in 'test_axs.c'
i have read the post about this question before,and it should be added a library. Although i added Labview.lib, i became this error.
(3,122 Views)
hello hakan_s,
you have to create your own c-file, where you program the code you actually want to implenent for your ActiveX server. you can copy the prototypes out of the generated h-file.
here is a tutorial for creating ActiveX servers in CVI.
regards,
robert h
NI germany
(3,102 Views)
