LabWindows/CVI
add __MSC_VER macro
Dear CVI Users -
I have third party hardware, driver and example C/C++/C#, VB and Python code.  I tried to create a CVI application (a basic .uir with a quitcallback) and added the .c, .h and .dll files to the project.  When I run the debug project, I get the error window:
Include file "stdint.h" was not found. Do you want to look for it?
I read that its for C99-compliant compiler (GCC), but that's not what I want ... right?  Below is the origin of the error from the 3rd party .h file...
#ifndef _MSC_VER
/* C99-compliant compilers (GCC) */
#include <stdint.h>
typedef uint8_t   u08;
typedef int64_t   s64;
#else
/* Microsoft compilers (Visual C++) */
typedef unsigned __int8   u08;
typedef signed   __int64  s64;
#endif /* __MSC_VER */
Since CVI does not define _MSC_VER, how do manually define the _MSC_VER macro to fit the above code?
Matt
Message 1 of 11
(6,537 Views)
Hello Matthew,
It looks like we have a KnowledgeBase Article here that gives you more information about this issue, #define _MSC_VER should do it for you. Please let me know if this does not answer your question.
With warm regards,
David D.
Message 2 of 11
(6,513 Views)
Hello David and Fellow-CVI-users,
Still have no success; I need to know where to insert the code and exactly how it should read.  I tried both
#ifndef _MSC_VER
#define _MSC_VER
#endif
and
#ifndef _MSC_VER
#define _MSC_VER
#define /MSC_VER 1200
#endif
at the top of the .c file with main() = Same Errors.
SUMMARY: When somebody declares MSC_VER, where and how is it done?
Thank you,
Matthew
Message 3 of 11
(6,506 Views)
Hello Matthew,
Did you try #define _MSC_VER <version>
Where <version> is the number corresponding to the version you are using as mentioned in the link I provided earlier.
With warm regards,
David D.
Message 4 of 11
(6,499 Views)
Hello Matthew,
I see that you said you defined _MSC_VER at the top of the .c file with the main function, but most importantly, did you define it *before* you #include the third party header file you referred to?  Perhaps the best way to make sure you have defined it in the appropriate place would be to do the #define in the third party header file, before the definition of _MSC_VER is checked.
NickB
Message 5 of 11
(6,479 Views)
Hi
I added #define _MSC_VER 1300 to the top of the header before it checked which compilier.  Then it jumps into the microsoft types, where  unsigned __int8 is not known because I get
  "aardvark.h"(81,27)   syntax error; found 'identifier' expecting ';'.
#ifndef _MSC_VER
#include <stdint.h>
#else
Is there a way microsoft types are known?  (i.e. there will not be complaints for unsigned __int8)
Your input is greatly appreciated.
Matt
Message 6 of 11
(6,466 Views)
Looks like you will need to provide your own typedefs, matching up the third party definitions with the CVI ones, available here.
JR
Message 7 of 11
(6,454 Views)
It is clear now.
Thanks!
Message 8 of 11
(6,446 Views)
Matt,
Did you ever solve this problem ?  I am having the same exact problem with the same exact header file /hardware.
Diego
Message 9 of 11
(6,098 Views)
Hi Spidyman
I modified the .h file as you see below in the first example.  Or a more simple way is to remove the #ifndef _MSC_VER ... statements as you see in the second example below.
//  first example
//  Not using GCC or Microsoft compilers
#ifndef _MSC_VER
//#include <stdint.h>
/*typedef uint8_t   u08;*/ typedef unsigned char    u08;
/*typedef uint16_t  u16;*/ typedef unsigned short  u16;
/*typedef uint32_t  u32;*/ typedef unsigned int  u32;
/*typedef uint64_t  u64;*/ typedef unsigned __int64   u64;
/*typedef int8_t    s08;*/  typedef char    s08;
/*typedef int16_t   s16;*/ typedef short      s16;
/*typedef int32_t   s32;*/ typedef int     s32;
/*typedef int64_t   s64;*/ typedef __int64     s64;
#else
typedef unsigned __int16  u16;
typedef unsigned __int32  u32;
typedef signed   __int8   s08;
typedef signed   __int16  s16;
typedef signed   __int32  s32;
//  second example
//#ifndef _MSC_VER
//typedef uint8_t   u08;
//typedef uint16_t  u16;
//typedef uint32_t  u32;
//typedef uint64_t  u64;
//typedef int8_t    s08;
//typedef int16_t   s16;
//typedef int32_t   s32;
//typedef int64_t   s64;
//#else
typedef unsigned long   u64;
typedef signed   char   s08;
typedef signed   short  s16;
typedef signed   int    s32;
typedef signed   long   s64;
//#endif /* __MSC_VER */
Message 10 of 11
(6,069 Views)
